Roue Bloqué
rodman
2 sujets en parlent sur le forum https://forum.electricunicycle.org :
1/ la méthode inmotion global : https://forum.electricunicycle.org/topic/14389-second-hand-inmotion-vehicle-discussion/
Recently, we have been receiving the request that the current owner(Second-hand owner) asked us to delete the previous owner info connected by SN(Serial Number). It can be done by our background system.
Here are some tips for a new owner:
1. Please request the previous owner to delete the owner info through the Inmotion APP.
2. Please keep the evidence like a receipt to prove you are the new owner. If no, we can't operate it before you are verified as the new owner.
How to connect the app and verify the new owner? (If the previous owner refuses to delete the info, or you can't contact them)
1. Send the receipt or transition record with chat record to our service team in English. (Sorry, we don't have other language service staff from the Headquarter in China.)
2. The previous owner info will be deleted through our background system.
3. Connect the app and verify yourself as the new owner.
Contacts:
Option1:Service@imscv.com (Recommend)
Option2 Marketing@imscv.com
2/ une 2nde méthode : https://forum.electricunicycle.org/topic/25075-used-v11-how-should-seller-remove-themselves-as-owner-solved/
  1. Open the INMOTION app, sign in or create an account
  2. open the "ME" tab
  3. Tap under your username where it says 'no registered wheel' to pull up the Ownership Verification page
  4. enter your serial number there. (This is a case-sensitive text field!)
If that doesn't work, the current owner can follow those same steps to delete the wheel from their account. (app > me > tap the wheel under their username > ownership verification > trash can icon)
rien indiqué elle etait emballer dans son carton, juste noté dans l'état.
je savais qu'il y avais un risque.
après si je ne la remets pas en route j'aurais des pièces à vendre.
la roue à 3km au total
Modifié par rodman
  • Triste 1
Il y a 8 heures, v5f06 a dit :
Certainement in problème de batterie,essaie de voir la tension avec wheelog lorsqu elle est chargé a fond,verifie la tension du chargeur aussi avec un multimètre.
Fait un diagnostic avec l appli inmotion.
Bon apres tu l a acheté en l etat donc j image pas chère.
Oui je l'ai pas payé 1500 euros heureusement. Oui le diag est bon.
La batterie est a 100%
Il y a 9 heures, genialmaniac a dit :
N'est-elle pas en mode transport dans l''application ? je sais ça parait trop simple mais bon on ne sait jamais...
Oui premiere chose testé après le diag. Mais non pas ca malheureusement
il y a 3 minutes, Phil 95 a dit :
Salut, pas sur que ce soit une si bonne affaire, la v10f est à 1349€ chez Amazon ou darty avec la garantie qui va avec.
oui heureusement que j'ai pas mis autant. après tu connais les garanties inmotion france ?
je peux te les donner passer les 15 premiers jours ils bottent en touche.
Il y a 9 heures, v5f06 a dit :
La tension est bien la bonne
il y a 8 minutes, edae a dit :
En fait tu ne sais pas s'il s'agit simplement d'un blocage logiciel ou s'il y a un problème matériel en panne
alors je pense a un blocage logiciel,
niveau matériel l'appli me donne pas de défauts
la tension de la batterie est bonne.
après il y a peut être un autre soucis mais je n'arrive pas a savoir lequel
